finally dual viair 380's
Got the dual viars up and running after rebuilding the one… And hopefully it will all hold air tonight . will find out in AM.
Wired it all with 4 gauge back to the dist. block. , and put in another dist block for the ground which also is 4 gauge to the frame.
The power feed to them is perfect now (some may say over kill) but it performs great.
Heres some pics of the setup…
Finally is right! j/k
It looks great - nice and clean. For not liking wiring, you do nice work.
You should enjoy your setup a lot more now.
Loving the Techflex!
Thanx, I’m learning more and more about wiring… So with that everytime i do something new it gets better.
Good eye on the techflex…
Although i think the one i got is called something different. But i wanted something to protect the 4 gauge under the truck, but still easy to use. I HATE using the plastic crap that cuts your fingers up trying to feed it… this expandable one works great.
Heres where i got it from .
I need to find some of that flex locally for when I install my next three gauges. But I believe I know who may have some.
Sorry for the T/J, but it’s relevant to your Techflex…
For sizing reference here is some 1/2" Cleancut Techflex over 1/0 and 4ga.
If you’re buying it in person it’s easy to see what size to get, but otherwise, just know that it expands quite a bit from it’s listed size. Here’s the same 1/2" stuff compressed:
/ T/J
I definately went too big for mine. But i did not know how it worked until i had it in hand… But the 3/4" still looks good and was easier to feed the 4 gauge thru it.
I just checked the tanks and i lost 2 psi in the last 4 hours… Id say thats pretty good since the temp has dropped 10 degrees since i filled them.
Loctite 545 fTW!
