aww man that sucks. what is it you’re looking for? i dont read:eek:
Venom - did you read my post bro? Does Lowe’s not have what you are looking for?
Jeff, I havent had time to get to lowes since I got laid off, I know homedepot didn’t have it, nor did my local hardware store. I need some more hose for the shockers to finish as well as run the electrical. I’ve kinda put it on hold til I can find the parts Im after and til I can get back to work
TECH GURUS’
What size NPT is the male end of the shocker horn? I know the tubing feed is 5/16 and my truck isn’t here so I can’t exactly go look. I’m either looking for a street elbow with male and female threads or a npt 90 to push to connect for the tubing.
The brass nipple that goes into the horn? If so, it’s 1/8" NPT
^ Thank you sir, I didn’t find any with 1/8 npt and PTC but I did find some standard and picked those up. Now I just need to get some hose and figure out the wiring.
You guys are a big help. I seriously didnt think it would be this hard to get it done, not to mention my motivation well…sucks.
Been there man. It’s not difficult to do, but it takes time and some thinking when it comes to running electrical and airlines. Plus I’ve worked on it a couple hours at a time when I can get to it so it just takes that much longer! I’m finally honking mine since last Sat but I still have some more wire and airline to run for the remote pressure gauge and manual valve. Ugh seems like it’ll never be finished! Hang in there it’ll be worth it!
My petcock broke right off as well. I have been using a pair of vice grips, but that is taking a toll on them. I need to rig up a solenoid a well to dump out the water.
I used a 3/8 (the original solenoid I got with the system) to hook up a remote dump off valve. I’ve also got my tank mounted upside down to the bottom of my bed. a buddy of mine used a 1/4" remote solenoid for his setup.
Yo!
If you need those elbows Hornblasters has got em! If you cant’ find em anywhere else they’re 1/8" F NPT- 1/8" F NPT 90’ elbow… we’ve got them for like $2.00 each… we can ship them USPS for almost nothing!
877-209-8179
When in doubt, give us a call!
yo Matt, i might be coming out to HB within the next week or so. live in the Tarpon Springs area so you guys aren’t that far…
Hi venomous. I suggest that you should change it now.
