Frequently Asked Questions on: Train Horns, Tank Size, Compressors and MORE...
Frequently asked questions on horns, tank size, and compressors
I will update as I find necessary, and if you have something to add, just post up or pm me and I will add to the list. Thanks
Best PSI to run the horns at
For actual train horns such as Leslies and Nathans, run them at 150psi or below. Running them at 200psi changes the tone of the horn, and actually decreases the decibel level. It is only louder to the human ear.
For the shocker series horns… The shockers are a tough horn and can be ran up to 200psi, with half inch line such as in the XL kit, it is suggested to run them at 150psi for an actual train tone. With the normal conductors special with 5/16ths line, 200psi sounds amazing, Its noticeably louder than 150psi and I highly recommend it.
For other horns such as psychblasters and such. I saw in the terror of the streets videos, Hornblasters used 175psi on the horn, I have used 200psi on the original valve for a couple of years and it still works fine and sounds great too. I would say 200 and below, just like the shocker series horns.
Best Air size to run horns at
For actual train horns such as Leslies and Nathans, ½” works great, anything less and your restricting the airflow to the horn.
For shockers and psychoblasters, either the 5/16” or ½” line works. With ½” line, the horns will draw more air, making them louder, however since it draws more air, you will go through your air supply faster.
Optimum Tank size
If you own or want to own an actual train horn such as a Nathan or Leslie, 5 gallons is the minimum. Leslies use more air so I would recommend more than 5 gallons. The bigger tank the better for these horns. And as with VIAIR’s warranty, 5 gallons of tank per compressor. Oasis compress can handle a much larger tank size so that doesn’t apply to them.
For the shockers at 200psi or XL shockers with ½” line, I would suggest a 5 gallon tank or more. Less is ok, but with 5 gallons, you can get a decent amount of honking time.
For the occasional honker, who doesn’t go around blasting everyone, just uses their horn in emergency situations…
~2 gallons is fine, I used it for about a year and 2 gallons worked, I later upgraded to a 5 gallon because I was sick of hearing the compressor all the time.
Compressors
If you have any questions with compressors Lance and Dan, are the gurus to this forum. They can answer pretty much anything asked.
What is CFM?
The notation CFM (Cubic Feet per Minute) refers to a volume of air produced by the air compressor at a given pressure or PSI (Pound per Square Inch)
What is Duty Cycle?
A compressor’s duty cycle determines the percentage of run time in a full cycle. A full cycle is determined by adding the compressor run time to its rest time.
Does a compressor that has 100% Duty Cycle mean that I can run the compressor all the time? Can I run my compressor 24 hours a day?
No, you’ve got to remember that duty cycle is rated at 100PSI, at an ambient temperature of 72°F, but certainly a 100% duty cycle compressor can run for much longer periods of time than a 30% duty compressor under the same conditions.
I’m interested in a compressor for my on-board setup. Which compressor would you recommend?
We would recommend either the 400C 12V air compressor or the 450C 12V air compressor for your setup.
How do I know if I want the 400C or 450C?
The 400C pump is rated at 150psi working pressure and the duty cycle on this unit is rated at 33% duty at 100psi in 72 degree ambient temp. The 450C is rated at 150psi working pressure, the duty is rated at 100% at 100psi at 72 degrees ambient temp. TIP: If you need duty cycle, go with the 450C. If you want speed, go with the 400C (it is faster than the 450C).
What else would you recommend for my on-board system?
Here are some suggested component parts for an on-board air system:
PART NUMBER
TA-508: 5.0 Gallon Tank with 8 Ports
PS-150R: 110/150 PSI Pressure Switch
VA00035: 35ft Hose with Close-ended Tire Chuck
Does a new compressor have to be broken in?
No, they do not. Typically after an install, you should power up the system from 0 to whatever the cut-off pressure is and check for any leaks that may be present.
How do you check for leaks?
You can check for leaks by putting soap and water solution where the fitting connections are. If there are bubbles present that grow in size, then there are leaks.
Does it matter where I install my compressors on my vehicle?
This depends on several factors such as available space, whether or not the compressor is of a sealed or vented type, as well as personal preference and aesthetics. Make sure to utilize the rubber insulators to keep vibration and noise to a minimum.
How can I tell whether the compressor is sealed or non-sealed?
Manufacturers will normally specify if a compressor is sealed against moisture and dust, and in many cases, you can tell the difference by simply inspecting the compressor. If you see vents, cracks, or holes in the motor housing, then the compressor is not sealed and must be kept away from dust and moisture.
Why is it important to have a sealed and moisture-resistant compressor?
The preference of a sealed-type compressor is due to the fact that in mobile pneumatics, compressors are likely to be exposed to outside elements.
Is the 550C compressor sealed and weatherproof?
The 550C is not a sealed unit. If you want to mount a compressor under your truck, you might want to take a look at our 450 series. While it is not as fast as the 550 series, it is moisture and dust resistant and can be mounted under your truck. Also, we have new compressors that are more suited to exterior mounting (420, 460C, and 480C).
Is it possible to mount the compressor sideways? Must it be mounted with the cylinder upright?
Yes, you can mount our compressors in any direction or position because they are oil-less. The only position we do not recommend is an upside-down mount, since heat tends to travel upward.
If I mount my compressor sideways, like on the frame rail of my truck, is there anything I should be careful of when doing this?
If you mount your compressor sideways to the frame rail, you should periodically check to make sure that your compressor is mounted securely. Use a thread-locking compound to keep the screws from backing off and causing the compressor to be mounted loosely.
Is it possible to hook up more than one compressor to a single pressure switch?
Yes, it is possible to use one pressure switch on more than one compressor. You should always run a relay if you want to hook up multiple compressors to a single switch. You should check the amp draw on the switch first, and then you’ll know how many compressors you can hook up to one switch.
Can I use an adjustable pressure switch with my compressor?
We don’t recommend that you use adjustable pressure switches with any VIAIR compressor. If you use an adjustable pressure switch, you can set the pressure switch higher than the maximum pressure that is rated for your compressor, or you may exceed the maximum rated working pressure for your air supply tank. Doing so will immediately void your warranty, not to mention, it is dangerous.
Is amp draw of the compressor something I need to be concerned with?
Yes, the lower the amp draw, the better the compressor is. As a rule of thumb, the maximum amperage that a compressor should require is 30amps.
The above info on compressors can also be found here:
http://www.hornblasters.com/support/compressor_faqs
Honestly, bigger is better. I have used the VIAIR 280c with my 2 gallon tank and it was by no means fast. I later switched to a 5 gallon tank and 480c and love it. As stated above, VIAIR’s warranty is 5 gallons of tank per compressor, so for a 10 gallon tank, 2 compressors at the least. Oasis compress such as the XD3000 is only limited by its duty cycle, not tank size. It can run about 30 minutes out of every hour at 200 PSI. That’s about 130 gallons. can handle a much larger tank size so the 5 gallon rule doesn’t apply to them they are workhorses but draw large amperage and are great for filling giant tanks such as duel 50 gallon tanks… lol
For manuals and wiring schematics. Follow this link to the Hornblasters site.
http://www.hornblasters.com/support/manuals_and_schematics
Glossary of Terms found here
http://www.hornblasters.com/support/glossary_of_terms
Contact Hornblasters
Please note our manufacturing and distribution centers are not open to the public. Visits may be made by appointment only. If you would like to make a visit, please call and make arrangements with an administrator.
The following addresses are not public store fronts.
HornBlasters Addresses
Florida Warehouse: HornBlasters, Inc.
39440 Pattie Road
Zephyrhills, FL 33540-3158
USA
Other ways to contact HornBlasters, Inc.
Toll Free: 1-877-209-8179
Phone: +1 (813) 783-8058
Fax: +1 (813) 783-2407
Email: sales@hornblasters.comsales@hornblasters.com
[b]AIM:[/b] 	hornblastershornblasters.com
[b]Facebook:[/b] 	www.facebook.com/pages/HornBlasterscom/116247935013
[b]Myspace:[/b] 	www.myspace.com/hornblasters
[b]Twitter:[/b] 	www.twitter.com/hornblasters
Twist, well done! You can delete this when and if you make any changes from my input.
Most people outside of the US use “liters per minute” instead of “CFM” and “Bars” instead of “PSI” if you want to include that information.
duty cycle only covers the first hour unless otherwise specified. The XD3000 has a 100% duty cycle @ 100 PSI @ 72 degrees but in the long run, you’re right. It can run at least 30 minutes out of every hour @ 200 PSI and a little longer at lower pressures. Our XD4000 can run continuously @ 200 PSI if you have the power to run it.
oil lubricated compressors must be mounted upright.
The overall current draw of all 12V compressors as related to CFM & pressure is about the same. To equal the performance of an XD3000 would require enough smaller compressors that would draw about the same amount of current.
