Ok here is what i am trying to do, i wanna use my factory horn button on my steering wheel and use a switch to switch back and forth between my factory horn and my k3’s, i know i need a SPDT switch but i was wondering about these push button style switches and if they work the same(On(fact horn)-off-on(K3’s), has anybody ever used these push button style switches? i would like to use this style cuz it will look good in my nnbs sierra, thanks
As long as it’s a toggle and not a momentary it will work.
I see 4 prongs, but are 2 of them for the light?
Even it’s SPST you can use a relay to do the switching.
whered u get those at?? and what type of switch is it?? i may use it…
I like the looks of that switch. But I don’t use the horn I have now so I would forget I have my train horn hooked to it. I will just run a separate button for mine.
Sent from my iPhone4 using Tapatalk.
What about the military style rocker switch with lockout?
http://www.frozencpu.com/products/5827/ele-260/Military_Style_Switch_-_Amber_LED.html
I know this one is SPST, but they should make them SPDT as well.
Kris
