HELP! Only 1 Horn is working
I bought the Klein S600 Z3 fullsize train air horn kit. I have installed the horns, air compressor, and tank. It is all wired up, BUT, only the large horn with the sulinoid is working. I have the large horn on the driver side, and the other 2 horns on the passenger side underneath my suv. It seems like the other 2 are not getting any air and all the air is going strait to the large one. Does it matter if the trumpets are seperated and have a few feet of distance as far as air tubing. The Sulinoid is connected directly to the large trumpet. Would adding air tubing between the 2 make it work?
PLEASE any help would be great. Thank you very much.
214-862-4949 Brent
yes making more threads will get you the help you need faster than ever!!!
take it easy, does that bother you? I want my stuff installed right, and I did not see my first one in the section.
rages me hard
do you have a link to the horn kit you have?
yes. http://cgi.ebay.com/ebaymotors/Fullsize-Train-Air-Horn-Kit-Car-Truck-SUV-Horns-150-db-_W0QQcmdZViewItemQQhashZitem19be43a559QQitemZ110566286681QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
you need a manifold, and maybe switch the biggest horn to the longest hose you use
