hey, my name is josh… new to the forum… well kinda… been stalking around here for a while reading and soaking up some of the knowledge on this forum. i bought some horns off a guy a while back and i finally got my pressure switch and everything fixed up. my problem is that my hose keeps bursting at the compressor (800lb hose) right at the end of the barb fitting… running 3/8 hose that is used on a regular shop system. My guess is that the compressor is causeing the barb to get hot enough to melt/weeken the hose in that spot? if so whats the best solution for this problem? just started an LED Light bar Business so i need to keep cost to a minimum lol
thanks for the help in advance!
