hey gettin my kit today. need help
I was lookin on some peoples threads and i was wanting to know if i could put the pressure switch on the end of the tank because i dont have much room. and where would be the best place to start getting everything put in the truck?
you can put the pressureswitch about anywhere, close to tank is more preferred… but as long as it is pressurized by the airtank it will work
What i did before install first is to find out what goes where and if it will fit. ie. where your airline will run from tank to valve
I just used the PDF for installation, pretty straightforward
good luck
Any tank port should work, except any on the bottom of the tank (they collect condensate and will ruin your switch over time).
Like Jelle said, anywhere pressurized is normally good too though. (Just ideally not on an output line)
