LOL… well thank goodness for that!
Now lets see some horn videos.
I’ll have to replace that and hope thats the solution. I went crazy! searched the grounds, the power sources, etc.
I was gonna be smartass and tell you to check you blinkers, but I knew your truck is a 2013.
Ya well I felt like an idiot. I even looked at m front lights but side there are chrome housings in the headlight I was looking at the reflection and thought it was good. Oh well, I ordered a new bulb so it should be good
Originally, I have my 1/2" tubing separated in two because I didn’t have enough to complete the job first time around. So I reordered new tubing this time in 30ft so I had enough to finish the job. Now the small leak I had is even bigger!
So, I redid all the fitting with the Loctite 534 or whatever people recommended and leak is still there. It cant be my hose because its brand new. any ideas?
So have you checked all your fittings with soapy water?
Maybe it’s the check valve or solenoid valve.
I tried that but I’m not sure of I’m doing it correctly. Just a spray bottle with a little dish soap in it? Sprayed it on the fitting and nothing. I’m not sure if I have one of those check valves. Ill have to check and see if its the solenoid valve.
Will there always be a leak?
No there shouldn’t be a leak and yes you will have a check valve. Have a read of this
Well I found one leak today. Was the Solenoid (Last one to be checked, go figure!!) Hope that solved all my leak issues.
