Has anyone ever installed a K3LA on their honda element? I really want to but just don’t know if there is enough room…
i don’t know but you can mount them separated just like i did with mine…
K3HA Mainfold
K3HA Mount Separated
Could someone post a picture of the back of the k3la… The part where the diaphragms are. Also, put a ruler or something in the picture if you could. Thanks! Also, where did you buy that detached manifold, and did it decrease the loudness?
What is the difference between the k5la and the k5ha? Also, would it come with the detached manifold?
Thanks,
William
The manifold is the only difference between the 2. One is a high mount and one is a low mount.
more info about mounting them separately?
they sound the same with the original mainfold, easy to install, not that expensive…
was hopin for more pics.
I looked at a site for the airchimes earlier and they sold individual manifolds for roughly 100 bucks each. Wanted to see other options to mounting the bells separately. Not much as far as real estate goes under a jeep wrangler
hey tri4ubb, so you separated a k3la to put on your car? i cant tell if you said you got 3 separate manifolds. if you had any pics thatd be cool because im wondering how that worked out
For you guys looking for the individual manifolds that tri4ubb uses… here’s the guys sale ad on Ebay that makes them… http://cgi.ebay.com/Nathan-Airchime-K3-K5-Train-Horn-Brackets_W0QQitemZ170337529270QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27a8e86db6&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|240%3A1318|301%3A1|293%3A1|294%3A50
yeah thats the sae guy i bought it from
wow, so do they work well and everything?
yep everything works awesome
