Horn issues
I recently got a set of the Rhino horns from hornblasters and only the smallest of the three is lighting off. I do not have any leaks and the tank is holding at 120psi. I wired the switch off of a cigerette lighter in the cab with 16ga wire. is this some type of power issue to the solenoid? or just a bad horn problem?
thanks
