Hornblasters PA/Siren
can u wire this unit to a 100 watt speaker…??
no you cant… and it wouldn’t matter if you could anyway if it only has a 30watt amp your still only going to get 30 watts with a 100 wat speaker
tis tru unless u ammplify it
okay i was just curious so is the HANDLE is the thing that makes it work or is there a side amp as well…
i think its built into the speaker part…
O okay…got you
What three sounds does it make?
lol what are u reffereing to?
wail, yelp, airhorn.
brizzal has a video of it on the first page…
this is kinda off subject but . when I buy a pa it will be that one … but just asking what ever made you want to fix up your devill. seems like you have a good bit of money in it.
i got the car from my brother’s wifes used car dealership for a great deal, plus ive wanted my deville since i was 7 years old when they came out
i was thinking of purchsing one of the new HORNBLASTERS PA for my brothers FOUR WHEELER…
I understand.
anyone figured out how to amp it? after I blast my horn people cant hear my pa:)
in order to amp it …u gotta connect a amplifier and to it… but im not sure how u would do that with the HB PA… and its a mess just tryin to connect a amp for a PA… might as well just get a device that output is about 100 watts thats alot louder
yeah I kind of figured that with a little hope but I guess I save up for the 100watt pa. thanks
ok I know nothing about p/a stuff but to amp one i think youd have to bypass the original amp which take some expert handyman skills and would probably include taking the whole thing apart cutting alot of stuff out and splicing new stuff in. if its anything like bypassing a stock bose amp i wouldnt try it without a pre fab bypass kit and even then its no walk in the park.
ill compare it to adding a ls6 in a honda civic, sure it can be done but in the long run it would be more sensible to buy a car with that ls6 in it already
it can be done. use an amp with high level inputs and connect the speaker outs of the PA there.
