Hi,
I know this is not a train horn install, but would like a bit of advice…
previously had twin air horns running off a compressor mounted in my Vespa Glovebox / toolbox. worked fine ( relay all fused etc…), have recently acquired some tasty Black triple Stobel air horns with a stobel compressor…
Now with this install, i wanted to make it as Stealthy as possible, Hence Black Air horns ( Black Scooter) mounted the horns under the floor boards of the scooter, and have run some pipe through the Chassis of the scooter… I have managed to mount the older compressor that was with the Twin air horns behind the Seat and hidden well out of way…( stobel compressor was just a bit to large in size) cannot be seen at all… I have a couple of length of pipes and connections between the compressor and horns and finding not enough power to run the three horns…
Do I ?
Mount the compressor closer to the horns ?
Use the Stobel compressor…?
Bear in mind the twin horns compressor did work when i connected the Triples straight to the smaller compressor…
Reduce the number of connections, reducers,
Or give up…!!!
Also was wondering could i use the spare tyre on the scooter as a secondary air supply…??
Al…
