Horns Worked Perfect Yesterday and Stopped Today?
So my train horns stopped blowing today. It’s the Shocker kit from Hornblasters. The compressor still charges up like normal but the solenoid stopped clicking. Why would it just stop and is there an easy fix? I checked the butt connectors up top for corrosion and they were clean.
If it helps… I don’t think it’s a power issue because the solenoid is wired into the compressor and the compressor is wired into the battery. Compressor works and pumps, solenoid doesn’t do anything.
Hooked two direct wires from the solenoid to the battery and the solenoid clicked fine. So what’s the next step?
Check relays and fuses and ensure all are working as expected…
if they are then check button for horn is as expected or that your getting signal from the stock horn wire tapped into.
Sent from my unknown using Tapatalk
