hot wire
ok someone plize help me out with this i have two viair compressor an a 10gollon tank that i just huck up today an on one of my compressor power wire is getin hot y is the wire getin hot. the way i got it all run is a 4gauge power wire from my battery to the back of my truck then i drop it down to a 8gauge power wire to the compressor an the grand gose from the compressor the a squre d pressotion switch to the grand on the frame ive got the press switch set at 200psi i dont want to mess up the compressor so i unhuck that one can anyone help me out on this im not sure what size compressor they are all i can read on the sticker is “200psi” i cant make the rest out cuz they been under my truck for 1 year now i just never power them up till my old compressor went out last nite the comp were all set up on the tank but i never huck them up to the horns i cap the tank off any help with this wood help out alot
there could be many reasons the cable is getting hot.
you might try mounting an auxiliary battery in the back, run the 4 gauge to it and run the 8 gauge to the compressors. if that doesn’t work, try running a ground cable between the batteries and the compressor instead of grounding to the chassis.
it was the ground the hole time i had to put a better ground then what i had on there
That’s good news then. Did you fix it by adding a ground cable directly to the battery?
