so my hadley semi horn only sounds at 60 psi or less is somthing wrong with it or is that normal. above 60 psi it just sounds like air blowing through.
I used a 1/2in valve (from my old k3ha set up) running through a 1/4in id air hose (2ft long) to a 1/4in barb to 1/8in fitting into the horn.
its a 26in long rectangle horn says Mack on the front
I would assume that’s normal as I don’t think many semi trucks really go above that in pressure. Before you take what I say as truth, I’d wait and let a couple of other people more familiar with semis give an opinion.
it might have something wrong with the diaphragm but I may not be so sure. I had tried running a couple horns that used a on-demand compressor (~7psi) and ran it at 125psi and it still worked… very loudly.
The air horns on my Western Star semi blow at 120-125 psi. I think there may be something wrong with your horn if it does’nt blow above 60 psi. Most semi’s run 120psi as compressor cutout pressure.
[QUOTE=mercer;35400]The air horns on my Western Star semi blow at 120-125 psi. I think there may be something wrong with your horn if it does’nt blow above 60 psi. Most semi’s run 120psi as compressor cutout pressure.[/QUOT
I wonder if my line is to big or if semi horn valves only allow so much pressure. It sounds fine to me at 60psi thats the only reason I think something may not be wrong with it, but I will take it apart tomorrow and see if it looks like (dont know y I never did that before)
My stock horns only have 1/4" line running to them. You might be right about the valve only allowing so mch pressure. I know I increased the cutout pressure on my commpressor from 120 to 130 in preparation for my P3 arrival and my stock horns sounded louder at 130 than 120. I would try your horn with another valve maybe? I’m pretty sure if that horn came off a Mack it should be able to handle 120psi no prob.
well I may have found it. I took my horn off my truck to look at it. and as I was taking off the fitting going into the horn it fell out of the horn (no unscrewing) The horn was striped wen I got it but I found a fitting that was long enough to get to the good threads. I did some looking around and found that other one that I was supost to use. so I used that wrong one on the install.
thanks. what do u mean by adjusting the back cap I dont think you can. there is just the diaphragm sitting in there is the back cap against it and I put the secures back until they stopped (did not force them when they got tight)
are u sure cause it sounds good at 60 psi I made a new video it starts the same as the other one but has the horn at 60 psi after. it was loud to not like train horn loud but a little louder than a car horn
well i stand corrected. Usually when a diaphragm goes bad or sticking you get blow by. You might be over powering it with the 5/8" air line. I would try increasing psi in small amounts. until you have no blow by. I have a set of grover shutter tones and run them at 100 to 120 psi. Let us know how you make out. What model are they?
Well I just got done doing some reading on the Hadley site. All their run 110/135 pressure switches. So form reading your sig your set up runs 150 psi. Being that you had a K3 I would assume you are running that Psi. I believe you are over powering that horn. Or diaphragm is still bad.
Is it possible that the diapragm has a tiny crack which at a low pressure would not affect the operation of the horn but once normal operating pressure is apllied results in failure? Have you removed and inspected the diapragm thoroughly?
I still have the k3 I just switched to a graham white valve (I have not been on in awhile so have not updated it) I ran 1/4id hose between the 1/2in electronic valve and the horn.
I saw that too that there compressor setups have 135psi switches.
idk I just dont get it. it sounds good at 60 psi so mabe I should just be happy with that and get a regulator (or use a ball valve as one)
