how to arrange horns on manifold
well i finalloy recived my horns massive thanks to realtrainhorns.net
all horns come seperate from manifold. whats there correct geneeral arrange ment and would it make much difference?
i know longest us the the middle. ten 2 other ones either side then were do i put the 2 shorest ones?
also if need be how much does it effect it if i move teh horns arround to fit my install loaction?
I don’t think it matters, you could put the other two horns on how ever you like. As long as you have at least 1/2 Inch Airline with a 1/2 Inch Solenoid you should be green to go!
Certinaly got 1/2" id stuff.
Just woken up after a wedding with free beers and spirts I won’t be doing anything on it today at all.
Ok so bells in x 2 1 3 x with 4/5 on either end.
How ever if I needed to go 1 2 3 4 5 or some thing line that would that matter? Just my little ute hasn’t got alot of room. I want to mount it pointing down
There should be equal pressure & flow from all ports in the Nathan manifold.
It’ll be fine.
Oh also does tank drain need to be on bottom? As it means I’ll need to make a bracket for it. I could mount it upside town and bolt it under neath tray. How ever drain valve would be on top of tank but I’d prolly just use a side port.
I live in central qld Australia 0 snow mostly dry weather but we do get some rain. 5-40 degree weather during the year is normal.
Really should have a way to drain the tank. Air is heated up when compressed into the tank and then the moisture condenses as the air cools.
Yep I was hoping the air leaving the tank at 200 psi would kinda force the water out.
I’ll just make some sort of bracket or use cheap pipe clamps like use to hold pipes to a wall or people use hold conduit to there cars/roof racks
