so im installing my horns and have run into a huge problem the kit i have came with the wrong quick connect valve its to big to screw into the compressor i need something to reduce it any ideas
unrelated i have a ford f150 with a bed box since i didnt have enough hose i had to mount air tank upside down hanging from the bed box looks good tho does anybody forsee any problems
You can use a reducer fitting. You either need a male x female or a female x male.
.jpg)
Water will sit in the bottom, so a drain port is needed. And you don’t want the rest of your ports at the bottom so that water sits in your pressure switch, leader hose, etc.
where can i get the fittings and thanks
Any hardware store should have them, otherwise online if you can wait a few days.
