I GOT AIRHORNS!! *loud video* Need help piecing rest of kit though
Sooooo I managed to shinagle some airhorns from the roof of an RV in a wrecking yard. No idea on there working condition but whatever, they were free and just need a little cleaning up. One is 30" one is 33"
Heres a few pics.
And I made a vid just shootin some compressed air into the line from my garage compressor @ about 75psi
http://www.youtube.com/watch?v=tMsv7ec9U9M
Soooooooo, I want these in my car. What the heck do I need to buy now. I know the basics like tank/compressor/1/4" line. But what I dont get is the pressure switches and relays and what have you. Im not great at that.
Id like to buy the stuff locally since shipping to canada is not fun. I just want to be able to push a button, or open a swing valve from inside the car obviously to make the horn blow. I dont want the compressor always running either… just when I wanna use it. But if a motorist jumps infront of me that Id like to get there attention, Id like for the horn to probly work instantly and not have to wait for the tank to fill. I also dont know how big of a tank I need here, would a 1/2gallon tank work?
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=220415085953
http://cgi.ebay.ca/Steel-1-5-Gallon-Air-Tank-Train-Horn-Ride-FBSS-6-Ports_W0QQitemZ220415029530QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item220415029530&_trksid=p3911.c0.m14&_trkparms=72%3A1215|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
I havent found much for kits that sell EVERYTHING youd need if you already had your own horns. My Budget is about $125 I would like to keep it under
Any advice would be appreciated here
always remember you get what you pay for… the compressor you posted isnt reliable, sure it will work, for about 3 weeks. $125 isnt enough to have even the bare minimum air set up, you need more than a tank and compressor
for example, http://www.hornblasters.com/products/details.php?i=viair-20003-1-5-gallon-air-source
Well yeah I defientely want reliable obviously, so that rules that one out if what your saying is true.
Its not that I only have $125, its just all I really wanna spend.
Like I said, Ive got the horns and figured that was a good chunk of the cost
I also dont have much IF ANy trunk to dedicate to this, so I was hoping to mount it under the car exposed to the elements…
I have a wall for a subwoofer setup in the rear of my suvs that takes up most of the rom
that smile after you honked the first one… you a hornblasters all the way!
lol thats the same thing my mom said when I sent her the video, shes goes “only you would smile at a noise like that”
I smiled the first time too.
the kit brizzal says is the the cheapest hornblasters got and is very nice and those are truck horns not train horns right?
the compressors look like viair replicas but I doubt if they offer the same performance. if you want to compare, compare the amps/psi/cfm rating table from the ebay page and the viair website. the ones in ebay show less current draw and more cfm for the same psi, looks good? I don’t know but I trust Viair more.
if you want low cost and good quality, get this one…
I’m using the same compressor and it’s doing it’s job well. just remember the saying “you get what you pay for” holds true most if not all of the time.
i also have the 24" in hadley of my own off a dump truck, great sound but hard to find a place to mount it and the horn wasnt loud enough for me
Electric motors vary in efficiency from brand to brand. None are 100% efficient, but within a small margin: more power consumption generally means more power. e.g.: a 26 amp pump is typically going to be more powerful than a 16 amp pump.
High CFM ratings don’t mean a lot unless they are at pressure (unless specified, they won’t be). Without resistance a weak pump can put out a lot of CFM, but test the same pump at 100 PSI and it might not hold up so well.
Viair and Oasis both give detailed CFM/amp ratings at different pressures for a reason: they make quality pumps.
I had another look at the ebay compressors. it shows they do have higher cfm ratings than viair but it drops off once the pressure builds up. the Viair’s I looked at showed a lower cfm at low pressures but maintains a higher CFM under pressure than the lower cost counterparts. I noticed it with mine when I switched from the china cheapo to a 275C. the chinese comp slows down when pressure gets above 80psi. with the 275C, you can still see the needle moving till it shuts off. :smiley: OK enough of that, I think we already know that good comps don’t come cheap. :wink:
I think I bought two viair 450c pumps for 300 from hornblasters and thats cheap if you ask me. I shouldve bought an oaisis though:mad:
my pumps dont run too often but when they do the sound solid and top off a 8 1/2 gallon tank in under a minute.
