Can someone tell me if its possible to add a second tank to an existnig setup (and how to do it) to allow for longer pulls of the horn?
I have the shocker set up from HB.com, and it is great except it only goes for a few seconds then needs to refill for good sound. Can you add a tank like this to the mix?
http://www.hornblasters.com/products/details.php?i=hornair-black-5g8p-air-tank
if so, how is it done? Im not askign for an exact wiring and tubing set up, but like is it run in series or something? Is the existign compressor enough to fill both tanks? I know it will take a little longer to get to peak PSI, but does it matter how big of a tank this compressor operates on?
the compressor is this one
Air Source Kit Compressor: Viair 280 Air Compressor
Voltage: 12 Volts
Max Amperage: 16 amps
Maximum Duty Cycle: 30 % @ 100 PSI
Maximum Working Pressure: 150 PSI
Length: 7.8 in (198.12 mm)
Width: 3.95 in (100.33 mm)
Height: 6.35 in (161.29 mm)
Weight: 6.6 lbs (2.99 Kg)
anyone have any ideas?
