I need alot of help with My set up
Hey guys-gals,
I have had my horns like ten years now:
I want to up grade my parts:
My pressure switch went bad on me.
I don’t know which pressure switch to get. What do yall recommend?
My other problem is:
I want a new tank, Bigger: Im looking at the 5 gallon w/8 ports, but those ports are 1/2 in.
So does that mean I need new air lines, or can i use 1/4" hose?
Also do i need to get a compressor that will fill that 5 gal. but also i dont want to break the bank for one.
My set up right now is set up on 1/4" hose, also with the 3 gal tank 1/4" fittings, pressure switch (blown) well at least has rusty particals in it, electric solenoid valve.
I never had a check vavle, or pressure gauge or blow off vavle/drain.
Please help as much as you can.
thanks in advance
what kind of horns you have?
if you are looking into a k3 or k5’s i would recommend getting 1/2" lines and 5 to 8 gallon tank with 1/2 inch ports @ 150 PSI - hornblasters has a variety of pressure switches. pretty simple to hook up.
this is the kit that i bought that has almost everything you’ll need minus the horns
http://www.hornblasters.com/products/details.php?i=hornair-540-horn-air-system
What’s your budget? It’s sounds like you’re toying with needing or wanting to upgrade everything. Best case you get a whole kit with everything for $345. 5 gallon tank, new compressor, new pressure switch / relay, including all your missing tank fittings.
If you just want a new tank and pressure switch - what kind of compressor do you have & what is it’s pressure rating. That will tell you what pressure switch to get. You really should have a drain, gauge, and safety valve…not to mention a check valve on the leader hose.
You can always get reducer fittings for the 1/2" ports. They come with the kit if you go that route.
What horns do you have?
Ive got the black 4 trumpet set up, but thats the problem i dont know the name of the horn kit i got ten years ago…anyways the compressure i have now runs at 1.57 CFM and the tank i have is 3 galllon w/3- 1/4" ports.
I really just want to get a new tank, reducer fittings to 1/4" if i can, a new 10’ hose to the front of truck and compressor and switch. but i know i will be getting in deep real fast.
ear2ear: what is the kit you speak of that is $345?
this is the kit he is talkin about
That is what im looking for, Thanks guys.
other ?
do i need to change my Electronic silanoid to 1/2" cause right now im running 1/4" ES?
Also my air lines to my hornes and to the spider unit is also 1/4", I didnt see but does this kit come with a diffrent ES?
You can keep your solenoid valve. The kit comes with a push-to-connect fitting for 1/2" DOT tubing, but you won’t use it.
Are you using rubber air hose? All you have to do is buy a 1/2" male NPT x 1/4" barb fitting for the tank port. Reuse your hose, valve, etc…
I don’t know if Hornblasters has any barb fittings, but maybe they would substitute if you asked. Otherwise I’ve bought some at the hardware store.
No, I was just using the hose they gave me in the kit.
Im glad they make a reducer for that ES cause i sure didnt want to buy a new one of those.
b4 i know it ill have enough spare parts to add another horn to something else…maybe my harley…Not!!! its loud enough…
Thanks for all yalls help, when i get the kit and have any trouble ill contact yall
apreciate all the Tips
Ok then I’m not sure what kind of airline you’re using. Just reuse the fittings on both ends and get a reducer bushing for the tank port.
Probably 1/2" (M)NPT x 1/4" (F)NPT bushing.
the hose that i use is this white semi clear plastic type that you can get at lowes. i bought 20ft for like 8 bucks there.
