What would be the best way to run a pressure gague into the cab of my truck?.. I’d would like to use electrical wires to the gague(no air line)… is this possible?
http://www.hornblasters.com/products/details.php?i=hornblasters-400-psi-digital-air-gauge
digital and uses wires instead of the air line.
Or this one is cheaper:
http://www.hornblasters.com/products/details.php?i=air-zenith-220-psi-digital-air-gauge
Thanks a lot… this is exactly what i was looking for… I’ve been looking all over ebay and could never find one, all i could find was digital ones that had to have an airline ran to them. The reason I want one is so i can manually control my compressors bc I’ve gone through over $100 in relays and pressure switches, so i think im going to do away with the pressure switch and turn them on and off myself. Thanks again, the help was greatly appreciated.
http://www.glowshiftdirect.com/Tinted-200psi-air-pressure-gauge.aspx
Has anyone ever used or heard of these? Im seriously consiedering getting this one sense its half the price of all the other ones. If anyone has any info on this gague I’d appreciate your input… Thanks
Running the compressor without a pressure switch is dangerous especially if you get distracted. You could void the warranty if the pressure gets too high.
Thats how I felt… those little oven pressure switches suck balls! so what i did was buy a square D pressure switch and its awesome!! never had a problem with this! try switching to a square d…
also i used this http://www.suicidedoors.com/air-management/air-gauges/air-zenith-digital-pressure-gauge-smoke-face
gauge for my tank… works awesome! pin point accuracy
