if you run twin compressors please HELP..
hi,
ive just bought an 8 1/2 gallon tank and 2 air zenith ob2 compressors from hornblasters ( thanks garratt ;0) )
they are going to be mounted in the rear of my car.
the battery is at the front of the car,im guessing im going to be using at least somewhere between 10 - 15 foot of power cable from the battery.
hornblasters have supplied me with enough 4 guage wire to run from the front to the back, but i had some confusion with the fuse holders so asked about the wiring.
now… im so confused on what to do:confused:
please help me out here id be very gratefull…
one persons telling me i need to run 2 lengths of 4 guage wire down from the battery ( 1 to each compressor )
and somebody else tells me theres no need…? and that just 1 length is more than enough to run both compressors…? as there only drawing a maximum of 35amps each.
im also told 4 guage wire can take up to 100amps is this true?
can you kind people please put my mind at rest and tell me whats best to do please? i dont want the wiring to burn out or get too hot…
also what size fuses to use would be great…?
many thanks,
i look forward to your replys… :slight_smile:
jason.
Our compressor typically draws 150 to 160 amps and we provide 10 feet of 4 gauge welding wire. Our engineer says 10 feet can handle 200 amps. It will get just a little warm at 200 amps. You can hold the wire in your hand all day.
You can probably use a 100 amp fuse for both or 50 for each but consult the owner’s manual or the company first.
You might even want to use 2 gauge or 1/0, and a 200a fuse
The only problem you would have is trying to find a place to run the water hose sized cable in your car.
Dan is right. One run of 4ga is plenty. It’s good for 150amps for an average 15 foot run.
http://www.knukonceptz.com/assets/pdf/PowerWireSpec.pdf
Use a 100 or 150 amp fuse near the battery…this protects the wire.
Buy a fused distribution block to split the 4ga into 2 - 8ga wires. (or 2 - 4ga wires)
Something like: http://www.knukonceptz.com/productDetail.cfm?prodID=BC-1428
I used 60 amp fuses for my OB2’s
Im running 2 Viair 444’s and all I did was run a single 4ga to the rear to a distribution block then I split it off to dual 6ga,one for each comp with a 50amp fuse for each.0/ga and 2 gauge is crazy overkill…
I was told to run two 10ga one for each compressor, but instead I did a single 6ga for both and hasn’t even got warm at all. If anything the 10ga from the comps will melt throughout before the 6ga wire does. Just to be safe I put a 60amp breaker at the battery then I did dual fuse at the comps 30 amps each haven’t had any problems at all.
Thats brilliant guys…:smiley:
thanks ever so much for all your help and replys…
one more thing… does it matter how thick the wire is thats used to wire up the pressure switch on the tank…? and if it goes to a toggle switch does it have to be fused?? if yes what amp…?
many thanks… :slight_smile:
That wire only triggers a relay which draws less than an amp. 18ga is fine.
I would fuse any wire connected to a positive source just in case your wire ever gets pinched & shorted. 5-10 amps would be fine.
Technically, if you connect to an ignition wire, it’s already fused somewhere. So some would say don’t worry about it.
There’s now 2 compressor threads in the train horn section instead of the onboard air section, just sayin, not tryin to be a d!ck or anything but it makes it sorta hard for people to find what they’re looking for when everythings in the wrong sections.
sorry if this is in the wrong section…
im now having some serious problems…
i keep blowing the 80amp fuse at the battery? is this not big enough…?
the comps will run for a maximum of 30 seconds then blow the fuse…?
strange thing is its only blowing the 80 amp one at the battery and not the two 40 amp ones at the splitter box at the rear :confused:
if the comps are only 35 amps max each, why is it blowing an 80 amp fuse…?
:frowning:
I believe mine are 38amps each or so…I wanted to be extra safe so I did 30 and fuses at each comp and one 60 amp breaker at the battery. Haven’t had one problem. Most likely you have a short somewhere between your comps and battery if you’re blowing an 80amp fuse. Or you messed up somewhere in the wiring.
Sounds like you need to be sure the grounds are perfect. Bare metal only for the grounds.
hi,
thanks for the help…
ok, so your sure 0ne 80 amp fuse will run 2 air zenith ob2,s…?
maybe its the earth then,would that blow the fuse at the battery if it was not a good earth though…?
many many thanks… :slight_smile:
Like Curt is suggesting - yes a bad ground can cause the compressors to draw more current.
The 2-40s might blow just a little slower than the single 80.
Yes and yes.
by fusing each compressor individually, if one blows the other should still operate.
