Install help toyota tundra
I’m going to install Shocker 548 set next week. I would like to know the best placement for the horns,air comp and 5 gal tank on an 08 toyota tundra. Thanks!
http://www.hornblasters.com/installs/class/?train_horns_on_trucks
follow that link to installs…
i already looked at the installs, but none of them are on the newer tundras. I’m looking for specific placement on tundras.
nothing is going to work as good as getting the measurements, a tape measure, going out and looking under your truck
Either that or if you got the kit allready try "dry fitting " them… or in other words, fits… dosent fit… Looking at the install section will give you a good idea of what other members have done and waht you can possibly do. You have a frame on your truck , you have a bed , you have a grilll… usually there is room behind all those / next to those / or inside…
