Right, Well the picture above is what the directions said, or at least what i could make of them. so i ended up just stepping back, thinking for a few mins, and drawing up the way i thought it should be, which was basically exactly what you said, i got it working… only to find a new problem.
i had the compressor running for almost half an hour, i was wondering what was going on, opened the drain plug and virtually no pressure escaped. so ive got a leak!!
i got some warm soapy water put it on every connection except the one i couldent see/get too, no bubbles, i have a feeling it is the pressure valve which is on top of the tank… not easily accessible. gotta drop the tank, which is a pain.
i was very careful about all of my connections made sure they were sealed and tight, properly threaded and not over tightened. my pressure valve (thing with the ring to pull and release pressure) looked a little odd to me, and didnt really move at all before i installed it, but thought for some stupid reason maybe pressure is needed to get it to work properly… my mistake…
The leader hose has a check valve (one way valve).
So the hose & valve have to be installed the correct direction.
There should be an arrow or something for the flow direction.
Hey, so i had some problems with a leak. just got it worked out, but apparently dont have the electric hooked up properly… right now i believe i have power to button to solenoid, and solenoid back to battery.
