Install with Scuba tank
I have done alot of searching on the net to find information about a truck horn install with a scuba tank.
The simple answer is yes, it can be done and for very little money.
All you need is a tank (which needs an inspection every 2.5years (£25) and air fill (£3)) and a 1st stage.
The first stage brings the pressure down from 230 bar to about 10bar (approx 150 psi) you then run the horn switch directly off a low pressure output on the regulator along with normal air/brake pipe.
I shall post pics or video of my setup as soon as i have time.
I do however have one question for anyone else that is running this setup. How long do you expect a tank to last for? I assume a fair old while given the pressure.
Well, I know that the tanks we use in the fire department are hydrostatic tested every several years. It’s only to check for leaks though… I don’t know the shelf life of a scuba tank, but from my guess it would be a long time like you said because of the low pressure.
Welcome to the forum!
Do you mean how long of a honk can you get?
I can’t answer that about a 3000psi scuba tank.
But for anyone to help they’ll need to know what horn and what size tank.
Line / valve size might help too - so list a few details about your setup…
Man, I’d hate to pay to have my tank filled up…lol
I think they need another type of test every 5years.
I run twin Hadley horn, 1 19 inch and 1 21 inches long. They are going on a car for the scum run 2010. Like the gumball but with cars under 500 pounds.
The tank is a 7 litre and is filled to 230 bar. The pipe is a quarter of an inch I belive.
That’s for the welcome btw.
230 BAR = 3335.874 PSI
To me, having to pay to fill your tank is an awful waste of income. -Even if you have a few thousand PSI to play with.
Welcome!
I dont see it as a waste. I already had the tank.
The rest of the setup costs excluding tank were about £30.
A normal setup is at least £300 therefore. There is a lot of refills before you have spent the extra £270.
The only worry is how long each refill will last.
I don’t know if anyone around here has used a setup like that.
There is a seller on ebay that is using NOS tanks - probably real similar.
You might contact him for some advice. Just a thought.
Got a link? Would like to ask him a question as im sure it will be similar.
Im running some horns off my CO2 tank, been doing that for a few years.
The reason I did it with CO2 cause I use it to fill my tires wheel 4wheeling, but Im starting to look into getting a small compressor and small tank just for the horns, and keep the CO2 for airing up tires.
BTW, I get my 20# tank filled for $12, with the horns and airing up tires every weekend, Im refilling it about every three months, so it aint to bad :cool:
What kind of horn do you have in this set up? Do you have enough volume of air coming out of the second stage to honk an HB4 or a K3? The reason I asked is that a diver only require a little amount of air compared to the volume of air a horn will need.
A 80 cu ft scuba tank at 3000 psi is egual to a 60 gal air tank at 146 psi
Thanks
Here are some pics and a vid of my install (not finished inside yet)
Excuse the half green, im in the process of preparing the car for the Scumrun 2010. Charity run across europe in a car bought for less than £500.
//youtu.be/<object width=“425” height=“344”><param name=“movie” value=“http://www.youtube.com/v/YmV457Kn2DE&hl=en_GB&fs=1&”></param><param name=“allowFullScreen” value=“true”></param><param name=“allowscriptaccess” value=“always”></param><embed src=“http://www.youtube.com/v/YmV457Kn2DE&hl=en_GB&fs=1&” type=“application/x-shockwave-flash” allowscriptaccess=“always” allowfullscreen=“true” width=“425” height=“344”></embed></object>
Pig, I watched the video of your supra, Do you have an anti-lag system on it?
Kind of, Its 2 step launch control. :slight_smile:
pretty sweet man
Scuba tank is a dumb idea, sorry. Just get at least a 5 gallon tank and a compressor and be done with it!
Yeah, but what if you want around 10 gallons of air and you can’t fit 2 5 gallon tanks on your vehicle?.. Then, what?
I dont know why people say its a dumb idea… honestly its a lot cleaner setup looks great and with non train horns like shockers hadleys and grovers it should last a pretty long time. and if you dont want compressor noise or dont have room for a tank and compressor its a great idea. my first setup was off of a 20# co2 tank and honestly if i do another setup i will probably do the same.
…not to mention easier to install.
That’s a pretty cool setup - definitely different.
Hey, try to let us know how long a tank lasts. Just curious
Im thinkin of doing mine like this. My bubby has a nbs silverado reg cab on bags with this set up. He has 2 of the big O2 tanks, he said when he plays with it alot it lasts about 2 weeks, but if just used normally, bout 3months…
