Installed 540: Questions & concerns...
Just installed the 540 kit and ran into some issues…
First, while leak checking I found a leak on the push connect fitting on the air valve(the 1/2 line). How are you supposed to fix this? I cant figure out how to get the hose out:rolleyes:
Next, the wiring on the press. switch…I had a feeling the wire size they used for powering the compressor wasnt exactly sufficient, and I was right, the white and red wires on the press switch get very hot while the compressor is running:(. I cut as much of the 14awg off as I could and ran 8awg for compressor power. HB really needs to use at LEAST 10awg on the compressor power wires IMO…
The push to connect is easy to connect … and disconnect. To connect, push it gently until you feel like it has stopped… Once you feel like you hit the end, push it a lot harder and it will feel like it popped in another 1/4" or so…
To disconnect , grab onto the fitting where the collar is that spins and pull it back towards the fitting itself. At the same time pull out the hose.
As for the wiring problem, i would contact HB directly and see what they recommend.
Thanks, I tried the method you described, but I guess I didnt pull hard enough:eek:
