…ran into one issue. We ended up, for whatever reason, using 1/4in airline. The solenoid will not open once the pressure gets above 90 or so PSI. Im going to switch the line out tomorrow to 1/2in to see if that helps. Does that sound like the problem/good first place to begin troubleshooting?
Believe I figured out the problem, the valve I was sent is 24 volt…I have no idea why they would send me one like that when it says 12 volt on the website.
I misread what he said, I thought he meant a 12v solenoid was weak, rather than one thats 24v running at 12. Thanks fellas, hopefully ill have the system running to its full potential soon!
i know some electrical is made 12/24v. wire it one way, and it 12. switch the wires around and you get 24.
try switchin the wires on the selenoid, as long as you have a fuse inline, the worst you can do is blow the fuse.
