A few weeks ago I went to use my horns and they sounded weird, kinda like squeaky and not loud sounding I thought. Later on during the day I was messing with them and they sounded fine again when I blew them, so I kinda disregarded it and they have been fine since. Now today I went to use them and they sounded like crap. I started messing with them and they would go from sounding normal to sounding reallyyyyyy bad again. Kinda weird. I’m not sure if its the valve sticking or something or if its the diaphragms in the horns. I know I’m getting full PSI and my line is fine too. I was thinking maybe I should take my valve out and clean it like the tutorial on the S10 forum shows. Any ideas?
That sounds like the diaphragms to me… There seems to be more and more problems lately with the squeak / squeal sound… So far so good here… (looks for wood to knock on…)
Even if it was the valve sticking , that wouldn’t create such a high squeal… When i use my manual valve an just let out the slightest bit of air , its always a deep sound… never a squeal… I would call up hornblasters…
I have the same problem and I got a replacement set of horns on the way… After I get them installed and a day or two of honking, I will let everyone know if the problem is gone! :FINGERS CROSSED:
Got the new horns on and I have not had a squeak since… I think it must have been a bad batch of diaphragms or something… So, my response to everyone who is having the high pitch squeaking problem is to return your horns and have the replaced
Yeah, I just took off mine and took the valve apart. It was clean inside and looked fine so it’s gotta be the horns on mine too. I guess I’ll call tomorrow or monday sometime.
i wonder if HB would just send out replacement diaphragms to those having the problem… Would probably save everyone some hassle… just a thought, but i dont work there … lol
So I thought it was the horns and was going to call HB and get an RMA number to get them replaced. Then I thought I should test the horns with my compressor in the garage to show my friend what they were doing. Well I did and they are fine, no squeaking or weird noises from them. So it’s confirmed to be my valve, which is weird since it seemed fine inside when I took it apart the other day. Guess I’ll be buying a new one soon.
