When I got the k3ha as I would apply air first the 4a would blow(the smallest high pitched bell) then 2 then 1. You would think this would be the firing order everytime…as ive broken them in its been changing. at one point it would only blow 4a until more pressure was applied then all would blow. then 1 (the big bell) would blow fisrt and you can hold the valve steady and blow just one horn for as long as you want. today I pull the valve just barely letting probably 20-30 psi to the horns and they all blow and Its the first time this has happened but before this its been changing everyday. Why do they do this?? ive got my own speculation but really dont know…
also for those who like to run theres over 150-psi. I contacted micro precision and they told me that its not good for them even at 150 and that they were loudest at 130 and i totally agree because when im getting down to around 130 120 or so they are noticably louder. all your doing at 150 and up is changing the pitch which will trick your ears into thinking they are louder not to mention destroying them.
