It's time to upgrade
I just removed my 2 sets of Shocker 4’s…looking to upgrade to either K3LA’s or K5LA’s…need some direction though.
Space is fairly limited so the 3 would be easier to fit…but is it worth the hassle to fit the 5?
What is the real difference between the two?
I’ve read that the 3 is slightly louder…true ?
I guess I’m asking what the benefit is to getting the 5 over the 3.
Thanks
Unless your picky with the tone…just mount the 3 if u can’t fit all five…and by decibel the k3 is louder
Came over from Quitting PSN LOL! Yes, Rich the K3 is louder then the K5 by a few decibels. Here You and others can use this chart.
Hope that will help you out.
Good Luck,
John
I’ve been a member here for a while…obviously not on much. LOL
Don’t have too many questions about train horns.
I hear ya. But you should be able to get a set under your bed if your not using your spare. If you need any help give a shout. Did a few on Fords. Also on my old 6.0 I had a K5 and a set of shockers, 2 five gallon slim tanks one on each side of the truck under the door on a CC. with 2 450’s.
I just filled up the space where my spare was with that 5" dual exhaust I built that’s completely tucked above the lower body line.
Ya think a k3la can be squeezed into the space on the front of the bed between the inner and outer bedsides on the passenger side of the truck…pointed straight down ?
I saw a set on a Dodge 2500 like that…tight but it worked.
Fabbing a bracket is nothing…I can do that easy.
Mods have to approve general posts ?
Wow…that’s annoying.
Lemme try again since there are no mods online…
Do you think a K3LA will fit in the space at the front of the bed, passenger side between the inner and outer bed sides pointed straight down ?
The space where my spare was is already taken.
It should there is a nice amount of room there. You will have to possibly have to build a riser or extended support, bolted or welded to the frame or bed rail underneath. Do you have a K3 now? If not I can hook you up with my buddy whom sells. PM me here or over at PSN. I go by JJKpowerstroke. If you want me to put you in touch with him. I figured being your ride is lowered the spare local would be taken.
Yeah, sometimes punctuation will trip it
And have you considered doing seperate mounting brackets?
Building brackets or even separate brackets is no big deal. As far as getting horns…I had a pretty direct line to Matt so I’m gonna see what kind of price I can get that way.
I’m open to all options though. lol
