I’m new here and I’m going to buy a train horn for my 02 ford focus… I think I’ve narrowed down my choices between Part #'s:
HK-S4-240 and the HK-S4-V238. I’ll just be using the horns for short blasts I’m assuming… no tire inflating or anything like that. What should I go with?
I’m pretty sure they are both S4’s…I think the only differences between them are one is 150 psi and the other is 200. Same size tank and One Compressor is fast fill while the other is constant duty… I’ve done all the research I can thanks to this site, I would just like some more info, maybe from the hornblaster guys. Which one??
Check it out… the 150 is nice and is loud , has a nice train sound to it… wwwhoooommmmpppp
the 200 is like WWWHOOOMPPP!!! not so much trainy tone to it but LOUD AS HELLL i have had both of them. and i go directly to hornblaster to buy all my stuff…literally to their warehouse and get my horns. its the only place to go to.
anyways the compresoors wont really matter that much because u are using them for short blasts and neither does the tank size so either would be fine
Here’s the pros/cons:
240 Kit (150 PSI):
Pros:
Fills faster which makes up for the small tank. The refill time is just about 40 seconds.
It has a deeper tone all the time since it fills to the range the horn is designed for (90-150 PSI; the horn handles more pressure, but sounds best in this range)
Cons:
You’re limited to honking between 150 and 90 PSI which only gives you about 7 seconds constant.
V238 Kit:
Pros:
Extremely loud. The extra 50 PSI really makes these horns shocking.
You can honk between 200 and 90 PSI which means your 2 gallon reservoir lasts a lot longer.
Cons:
The horns aren’t quite as deep (between 200 and 150 PSI) and don’t sound quite as authentic.
The compressor tanks a little longer to fill up: a minute and a half between 165 and 200, or about 2 minutes and a half from 110-200. This is the price for being able to honk for longer.
