I see there are 4 ports to tie air into on this bracket. Which port is best or does it matter. I would assume a bigger port means more air correct or should each horn be mounted separately? My next question is how big of a ait tank do I need 3 or 5 gallon / ports? Then which compressor? I would assume a Viair but I’m unsure of what size I will need.Once I get the big stuff mounted, I will start with electrical and air line. Any advise you guys can offer up here is appreciated! Thanks in advance…
If you have room to mount the whole thing, leave them on the manifold.
If not, you can buy a bracket kit to seperate the horns.
I don’t know if anyone ever runs a P series horn at 200psi, so if you get a 200psi compressor (to store more air in the tank), you can get a regulator. Or else just get a 150psi compressor.
You can get one with a lower duty cycle as long as you don’t drain your tank 5 times in a row.
I agree with Belair - 5 gallons minimum. At least 1 - 1/2" port for the horns.
Old cast horns have a better sound than most new cast horns. On the base of the individual bells where they bolt to the manifold one side should say “Pat pend” for new cast, or “Pat pending” for old cast.
