new here seen the videos. I want some. 2001 crown Vic what would be the best type of horns for around 200 to 300 I know I being cheap but I want to upgrade. later.
Welcome to the forums.
There are a couple kits around 300, but if you already know you’re going to upgrade later, it’s worth saving for a while to get what you want. Otherwise you’ll spend a lot more money - buying everything twice.
At the very least I would look at the Rocker kit for 320.
http://www.hornblasters.com/products/details.php?i=shocker-228dx-air-horn-kit
thank u. I want to put in the grill in front of radiator there a lot of room from where lights and sirens speakers where installed would they fit OK?
Well one reason to go with the Rocker kit is that the 2 horns are separate. You can mount them any which way to get it done. The other Outlaw kits or multiple horns are hard mounted to a manifold so they are bulkier… and probably not as loud.
You should be able to get them in there somehow, but here’re the sizes:
Horn: Shocker S2 Dual Air Horns
Material: High-Impact ABS
Length: B3 14.75 in (374.65 mm), B4 12.75 in (323.85 mm)
Flare: 5 in (127 mm)
can you control blast time with a button or How does that work with the blast time it says I think 5 second blast time I don’t need that long of blast? thank u
They are referring to the 5sec blast time as if you where to hold the button down until the tank runs out.
Welcome, you controll your blast time, if you have enough air, whether you’re using solenoid or manual valves.
