all i can so is :eek: its so much louder then i thought it would be. ive been scaring people all day long since i got it, its so much fun.
ill try to get pics up but i have to take it back tomorrow because there is an air leak and the compressor is hooked up to a constant power wire so it runs with the car off about every hour. other then that the shop did a great job. hopefully i can get some pics for you guys:)
You should probably get it hooked to a switched power source or put a toggle switch in that way incase a air line ever breaks while your not around it wont kill your compressor and battery
The relay allow’s you to draw power from your battery rather than the ‘ignition on’ only wire. This way you won’t strain your stock wiring system. Check Hornblasters ‘install help page’ they’ll show you relay wiring diagrams.
