[b]Finally got the K3ha and the 19 gallon hornblasters tank w/ dual Viair 400c pumps installed yesterday. here’s what I refer to my" erector set " tank mount and pumps. all aluminum frame.
[/b] still have to crawl under the truck to get the horn set up and post
as I forgot to take my camera with me for the install. :eek:
OK got the close up of the tank mount to riser here you go:
and here’s the horn mounted in the spare tire well. had to use threaded rod to make suspension spacers.
the 2 risers have a additional piece of flat stock that it suspended bettween the front of the riser and the back.the footer for the tank is bolted to that suspended plate. quite secure. built the whole mount in my bedroom office, BUT boy have I got a bad case of aluminum filings in the carpet. DON’T have a garage in my apt. oh well
But Please note that those check valves can go bad after some time. So it is recommended that the compressor be above the tank. None the Less thats a pretty kick donkey setup!
