Water does not compress at all. none.
So if enough gets in there, it can lock up.
Well for some reason the tank drained last night so the compressors ran this mornin and seemed to run fine…had a little noise but I’m pretty sure it was the check valve in the leader hose. Gonna check this evening and make sure both compressors are running.
I’m also thinkin the water might have shorted the motor out and caused such a load.
