Ok people, need some help here.
I have a K3LA setup under my Cadillac SRX, for some odd reason, when I blow, they don’t sound like they did when I had them in my Dodge Ram.
My setup is as follows:
I run 3 Viair 480c which each independently feeds to my 15 gallon tank.
My output is a single 1/2" solenoid which connects to a 1/2" line that feeds a 5 port manifold, which in turn feeds each of the 3 bells independently at 200 psi.
Now, I have tested my solenoid and it works perfectly in opening and closing. What i don’t get is this,when I go to blow, i get a muffled sound as if they are not getting enough air. I have taken them down and inspected them, cleaned them up. I have even changed the diaphragms and rubbers in all with brand new ones.
This is almost the exact same setup I had in my truck with the exception of a bigger tank and an additional compressor.
I have dudes with those poompy $100.00 dollar horns :mad: killing me on the streets :mad: and its like I have a covering over my bells when I blow :mad:. I have taken into consideration that the space in my wheel well is not as big as it was in my truck and ground clearance is not the same but there has got to be something seriously wrong here for my horns to sound the way they do.
Any and all comments are welcomed in assisting with a fix. Thanks in advance
