K5 generations
I’ve got a good question here, how do you tell the difference between the 3 generations of k5hl and k5lla Nathan horns? I know there is a slight sound difference but is that it?
That’s a good question!
One for the Techy’s on here DBO or e2e.
Not sure how you define 3 generations. Aging the horns is difficult I think because parts are readily interchangeable on the K series and many in railroad life would have had some bits and pieces swapped around.
There’s some clues to be had when looking at the 30109 casting mark on the back cap. If the 30109 has large “O” for zero’s, the horn was probably produced in the 80’s, because after that the font changed to a narrower “0”.
If the horn is tagged or hasn’t had parts swapped I think the tag is still your best bet for telling the history of the horns.
The old K series Airchimes were sand cast, not die-cast. The early production K5’s which were shipped to Chessie are called “Big Tag” horns because of their large black tag (1976-77 Era).
In the mid 90’s to early 2000’s, Nathan tags were square edged and after that (up to present era) the tag corners were rounded. Then there’s the “Over the Road” edition (also rounded tag).
That’s about all I know. I’m sure there’s some guys on the Horn & Whistle board who can tell you more.
I noticed that on the bnsf GE units in the 5000 series were equipped with 1st Gen K5HLs. The 2nd Gen was on the early 7000 series and 3rd Gen is common on the 8000 numbers (mostly ES44C4’s) I found this info out on YouTube
The earliest horns were produced with a two-piece sand-cast 1L bell, and no raised letter bells. This is especially prominent in the K5HL as 3 of the 5 bells did not play the advertised note. Early ones play C, E (around halfway between D# and E), G, B, C. In the summer of 2007, they switched to the current manufacturing method with a one-piece 1L bell, and all other raised letter bells. These horns produce the “correct” notes: C, D#, F#, A, C. The newest horns seem to vary in pitch more than the older castings. The K5LLA was produced in the same fashion as the K5HL with different bells. The main tone difference is the change to using the raised-letter bells and the two-piece 1L on pre-2007 horns.
The K5LLA did not change as dramatically as the K5HL did with the manufacturing changes. Newer K5LLAs seem to have a more dominant 1L bell, but roughly play the same notes.
Another interesting note on the K5HL is that the #1 bell plays a big part in the tone of early 'HLs. The ones that play closest to E will sound better than ones that play closer to D#. Raised letter bells almost always play D#
In my opinion, the whole “generation” thing with these horns is clouded in misinformation: there only seems to be two major differences in these horns, so I don’t know how the ‘3 different generations’ got started.
Hope this helps! :smiley:
:d:d:d
So there’s 3 generations of hls cause with first gens they need a new sounding horn but it was too quiet then the decided to put the raised letter 1L with the non raised letter 1 2 3 and 4 bells then they decided that was still ntj lif enough so then the made the other bells raised letter while keeping the 1L the same so you went from smooth jazz being the first gens to London park or something that’s sounds musical but still kinda sounds a little harsh with the yelling or whatever then you went to lamp if god or heavy metal or someone throwing up to dry heaving then wth the lla you then got a step harsher and now it’s death metal first gen k5llas death metal band that need work second gen’s death metal band that is getting better 3rd gen’s death metal band that actually knows how to be aggressive
Then you got the different kinds first gens maybe second gens but not much if a difference the mch between the 2 except for maybe one that goes high then low sounding then the different kinda raised letter hls getting a raise letter who off market place so I assume it’s either gonna sound the kinda really hard higher sound where the notes are harsher and more spread out or the intense lower version or the somewhat calmer version then the even slightly more musical calmer version that’d be a cool version to have preferably but the higher typical lower kinda harsher sound it’s know for would be cool too or the higher sound but notes are more spread out if you have ig check my social and if you see a silver horn click on that that’s the higher more spread out sound I’m talking about then you have the typical sound well I can’t post the video I copied from a friend in dns I’d sent it too bt still distant train at night Alex c and raised letter k5hl nick silcox a video where he’s in his back yard or in his hard at his house and you see a silver horn with green backroads and green insides on a pole that might be the same horn as Alex c vide I mean it’s the same horn but I mean the exact hl cause they dnt all sound the same
i know more about k5hls. the first gen k5hl is the one with the low humming sound, mostly put on ES44DC and ES40DC variants. The second gen k5hl was also commonly found on ES40DCs and earlier ES44AC and ES44AC-H models have them. Newer ES44C4 and ES44AC(-H) as well as the ET44AH have 3rd gen K5HLs. 3rd gens and first gens are my favorite but they all sound really solid except for out of tune ones or ones running a low air pressure. You know how K5LLAs on ACEs have a loud booming sound? K5LLAs actually sound more like K5HLs than you might think, because the ace runs a higher pressure on the horn. K5HLs found on ACEs sound almost identical to the k5llas and when you find a k5lla on a gevo it is very hard to tell the difference. some ES44DC/ES40DC models also had late K5Hs that sound almost exactly like the first and second gen k5hl and I personally caught one myself. They are all similar horns that sound mostly different by their era and what they are running on.
