Im fully aware that a big tank is needed for long blasts, but all I ever do is quick honks >1sec.
Currently I have a Shocker 540 system in the garage that I had in my last vehicle. The 5 gal tank is just too big to fit in my new car.
So, basically what I want to know is will a half gallon tank work with a K5? I know it sounds crazy but I just need it for quick single blasts.
              Does anyone have any idea how the K5LA would perform with a small tank?
Obviously, I know I wouldnt be able to do long honks, but I just want to be able to get the initial sound correctly if that makes any sense…
              It might not work.  The K3 and K5 eat 90 CFM and a half gallon just won’t do it.
You might want to try the Conductor’s Special instead.
              3 gallon minimum for any K series
What kind of car?
You have plenty of options for tanks and can even daisy chain multiple tanks if necessary
              My Friend, You are ONLY Limited to your imagination.  ^^^ Siding with 98 Snake Eater. What kind of vehicle are you installing them on? Might be able to give you some Ideas.
