ok so i just picked up a set or k5s. i want to hook them up in a car. what does everyone suggest to get these runnin and soundin right? im new to this air horn business and am not sure what i need.
Call hornblasters and tell them what you have…they will get you a kit.
im prob gonna buy used. trying to save money as much as possible.
Depends really how often you will use them
prob pretty often HA!
Tank - biggest you can fit / afford.
Compressor(s) - as many as you can afford - lol
Pressure switch / relay(s) / toggle switch
Solenoid valve / button
Airline / fittings / gauge / drain valve / safety valve
Wire / connectors / fuse holders / fuses
Do you have any specific questions?
This thread will help with basic FAQ’s. Check it out and let us know if you have more.
Well your going to need the individual mounting bracket unless u make a big hole in your trunk and point em down lol
