K5LA install without manifold?
New here, searched installs on alot of forums and can’t find any info. re: not using the manifold. Has anyone tried installing the horns separately so as to be able to mount in different locations? I realize the individual horns would have to be tapped with pipe threads, will this ruin them?
Installing on a '07 F350 Harley Davidson Ed. with an Oasis 4000 and 5 gallon tank plumbed with 1/2" d.o.t. tubing.
You can actually buy a kit for this, Curt S is the guy you want to pm if you want to buy one, or you can make them. either way.
http://trainhornforums.com/member.php?u=439
Thank you, I’ll look him up…any advice as to whether or not it changes the sound?
I have two of mine mounted separately and NO it does not change the sound. The sound changes if you use to much pressure or if you face A couple of the horns rearward, but only minimal.
Thanks! Finally found a link to Curt’ website (needed an azimuth) and he has what I’m looking for. Thanks again for the replies. Now I just to design the install/ locations.
How would you make one? OR what is it you’d need to buy?
Just send me a pm. :slight_smile:
