Kinked line
Arrgh! I tried to avoid this, but I kinked a line snaking it through the frame of the ice cream truck. It looks ok, but should I replace the line? It looks to be holding air well and doesn’t seem restricted. :mad:
Double Arrgh! I cut my 1/2" line in four equal portions to power my horns and then discovered it was the wrong line. :mad::mad::mad:
Clueless
If Its going to from the tank to the valve I would check it with soap and water to see if its leaking… If its just running to the horns from the valve though, I would say its alright… that is unless its major kinkage…
i personally would replace it… cuz it will give u problems down the road… thats just me…
Thanks guys, that was excellent advice.
I didn’t know I was doing the right thing at the time, but I left extra play in the 1/2" air lines so I can cut out the damaged part and repair it with one union rather than two. I’m going to stock some spares too, you never know.
