I wanted to do some subtle paint on my Trailblazer SS…and recently found this ‘fad’ that has been gaining popularity in the automotive world. The BMW guys have been doing it for a while now, but its finally progressed into about every aspect of the auto world. So just in case you guys haven’t heard…
Its PlastiDip. You can find it in your local hardware store. Its cheaper on Home Depot or Lowes…but it can be found in several other smaller stores too. Its available in black, white, red, and yellow. It dries to a flat…almost satin finish, that has a rubber/plastic texture.
Here is my front end before. The brake ducts are chrome plastic, and cracked when you look at them close. I’ve been wanting to do something with them, and found you can’t really remove them too easily.
Here is after…
And the biggest thing that people PlastiDip…the emblems. If you clean around them really good…use a toothbrush and some good cleaner, then let it dry well. Mask around like I have done, and apply your first coat pretty thick. Lay it down thicker than you would if you were spray painting. When you have laid down your first thick coat, apply as much as you feel is needed to get good coverage. Then remove your masking tape after its dry…and roll a corner of the painted section. You can then peel the excess off from the body…and it will usually stay intact, and allow you to peel around the emblems with no cutting or anything. Its awesome.
Peeled the masking tape off, then peeled the excess PlastiDip off of the body…here is what it looked like just after peeling the excess body paint off. Just a little weeding inside…
So I decided to do the rear fascia too. Here is before…
And here is after…even painted right over the hitch too. If you look REALLY close under the hitch, you can see the draincock from my HB 5 gallon tank sticking down.
Figured I’d share, in case you guys haven’t seen this stuff yet. It works great on all sorts of trim also. There are guys painting their ENTIRE car with PlastiDip. Also wheels…all kinds of stuff.
The best part? If you don’t like it, you can peel it off.
