ya it was funny at first but by the time all the air was out i felt pretty dumb. once I got to low pressure the horns started cutting off so the lowest pitch horn lasted forever
that gives me an idea. what about putting a solenoid and a switch that you can use to blow out all the air if your solenoid for the horns get stuck open. would help it run out of air faster. :rolleyes:
Mine is teflon taped as well and mine will hold pressure for at least a week. The only time mine lost pressure was when i would blow it in January and the valve would freeze open a little. Now that it’s warm, I can park it and come back a week later, switch the power to the compressors on, and nothing but silence.
Some people put a solenoid on the drain on the bottom of the tank…so they don’t have to manually drain the water out of the tank.
