The ones with the shorter lines will sound first. If you are using a solenoid, this probably will not matter. If you are using a manual handle valve, you might want to make them even lengths.
I would also make sure that the tube you are using is rated for the correct pressure.
Well, it’s under pressure as soon as you hit the button soooo …
I would swap it out with something rated for dealing with pressure. Vinyl won’t handle those pressures for long, and it’s easier to do it now versus trying to replace it once you have it installed.
What air pressure are you sending to the horns anyway? By looks of them they won’t need much air so you shouldn’t have any issues. Those fittings are just push on barbs onto the horns?. If they over-pressurise they should just pop off so no big danger
