Any tips or pictures on mounting the manifold to the frame rail or bed rail? Thanks
What type of vehicle? Browse through other installs in the install section and you’ll see how others have mounted theirs. You can find my install in my sig. I drilled through my frame where my spare tire goes to mount mine.
Welcome to the forum!
I have an 04 f250. It just looked tricky with the bolts surrounding the air inlet.
Ah. I plugged the inlet on the bottom of my manifold and used one of the ports on the side of the manifold to attach the air line. Here’s a pic of mine mounted in the spare tire spot. You can just see the air line between the bells running from my manifold to my valve here:
Great pictures. I really appreciate it. Looks like I have some work ahead of me.
Thanks. Read up on here and you’ll get a lot of information and of course if you run into a bump, ask away! It can be a bit time consuming to install, but once you finish and hear those babies blow for the first time, the work will be worth it!
Oh and post pics! We all like to see how others tackle their installs…
