I have just received a Viair 400C air compressor and was wondering whether or not it would cope charging my 5gal. air tank to 120psi? I have a 90-120psi pressure switch. So generally, it would only be charging the 5gal. tank from 90 to 120psi. Would the compressor be able to do the first 0-120psi charge in one go? Or would I need to stop midway through and let it cool?
G’day, Viair has a warranty limit of 5 gallons per compressor so you should be fine. The 400C has a fast fill rate so unless you blow your horns a lot its 33% duty cycle should be enough.
Cheers, Dan. I just hooked it up and gave the tank a charge (0-120psi). It took about 3 minutes. I am very happy with the performance of this compressor. It is fairly quiet, too.
