Is anyone on here from Melbourne Australian and have had someone install their horns? I have fitted the horns but having problems finding a good spot for the tank & compressor and would like to take it to someone who has already fitted a kit.
MC
MC
What horns and what vehicle?
Its a Toyoya Highlander/Kluger 2WD and ist the Shocker 240. I have installed the horns are in the front grill. The tank and compresor should fit were the drive shaft for the 4WD would normaly be but some brackets etc will need to be made up. I could go to any place and get some brackets made up but it would be easier if i went to a place that had installed a set before.
are u opposed to putting it in the trunk. Do a clean install in the back. U could put the compressor in a little battery box
Trying to avoid having it in side the vehicle, need the space and also the extra noise is not good.
im sure it can be doneā¦
