Mounting a Nathan K3
I am working on my 2nd build, first build I bought a bracket with a gasket & the four bolts, the horns slid right on and I connected the air fitting on the backside of the bracket.
I can’t find that same bracket, so can someone give me a picture or a quick way you guys mount them? I plan to keep the 3 horns all together (all connected to the ‘horn stem’). I have some scrap pieces of metal, not much of a welder. I am mounting them in the spare tire area of a GM 2500 truck.
Thanks in advance,
Are you saying that you’re going to use the Nathan manifold made of cast aluminum - and just need a way to mount it to your spare tire area?
You can also buy individual bracket kits on ebay if that helps.
Yes, I will use the manifold with the 3 horns attached to it, just looking for a good way to mount the whole thing. I will likely have to have them pointing towards the ground
