Well its taken a few weeks but I finally got around to install my horns and I want to say thanks to Garrett…I am a member of cummins forum as well and was hooked up to call Garrett and as they say the rest is history…he gave me a great deal and I am passing that along any chance I get
I did things a lil different from instructions but with the same results…LOUD HORNS
Heres a few pics of my install and feel free to point out things that I should change or make better…this is my first time
this is the kit as I unpacked it on my tail gate
We made a custom mount…I was going to mount on pass. side between frame and body but the floor pan rolls down on the outside and made the horns stick down about an 1"…not cool
A back view a mount setup and the small pieces of line…I had to try them at work…very loud
I mounted horns in the spare tire area…worked out great
I mounted compressor to a small plate and then used SS straps to fasten it to the crossover member for tranny…really worked out good…I also added the isolator blocks and that helped with the noise and the vibration
Here is the supply line for the compressor…their is 2 holes thru the frame that worked out great for the line
This is my tank setup…first off we welded 4 bolts to the frame for our mounting of the tank and then I used a “T” on one end to supply the air to the horns and also the pressure switch…worked great and kept things up out of harms way
these are my switches…1 is the trigger for the compressor and I used the other for the solenoid for the horns…I did not tie into factory horn circuit
